Model surface has obvious warping deformation
The base area or overall size of the model is large, resulting in a larger tensile force and substrate warpage when the model is cold. Then please check following possibilities,
1. Nozzle height and platform compensation value setting is unreasonable
- Reset nozzle height
- Calibrate the platform manually
2. Chosen print speed is fast
- Choose “Normal” or “Better” print speed
3. Platform temperature is not enough when the print task starts
- Warm up the platform for a while before transferring the print task
- When transferring the model, select the “Warm up” option. After transferring, the platform will warm up first, and then start nozzle heating and printing
4. The model cools too fast when printing
- Adjust the air volume of the nozzle fan to the model by adjusting the air switch of the nozzle assembly
5. The size of the model base is large, and the filling method isn’t changed accordingly
- Set the filling to a looser option within the software
