Skip to main content
Cetus ROM Update (NOT firmware)
13 comments
  • moebio
    Would like to do the same thing, but I'm on a Mac.
    1
  • tdevaney
    I have the same problem
    0
  • francishui_sg
    Hi
    Kindly explain what version is Cetus extended KS300 - S12_R_161128.ROM for.
    Thank you.
    0
  • Zach
    电脑和打印机通过USB相连后。刷机软件仍然显示no printer。请问如何解决。谢谢。
    wenyu@wustl.edu
    0
  • sealight333
    Hi,
    Could you please add the Cetus MKIII ROMs as well?
    Thanks!
    0
  • Jason Wu
    Cetus extended KS300 - S12_R_161128.ROM is a obsoleted Cetus extended version that has a 300mm Z-axis range. The normal extended version only has 280mm, so only Kickstarters will find this rom useful.
    0
  • sealight333
    Dear Cloris,
    Can we have the Cetus MKIII ROMs as well?
    Many Thanks!
    0
  • Josse
    I have been experiencing problems with the Cetus CPU.
    The link to the CPU utility on this page didn't work.
    If you ate experiencing the same problems as me, please consult
    https://www.cetus3d.com/roms/ for the CPU Utility exe file.
    0
  • Rodsterman
    I installed the Mk11 to Mk111 mother board and followed directions to download new Rom.
    Now Nothing works at all. The CPU utility flashed update in less than 1 second. I don't think it worked.
    Please advise
    1
  • JME3D
    What about MK3??
    1
  • mykey
    Hi Do i need a ROM update for my mk3 when i wan to use a touchscreen?
    2
  • Jason Wu
    The last 2 files on the list are for MK3.
    For touchscreen update, it will include a new CPU to be compatible with the touchscreen.
    0
  • carlos.13.hurtado
    Cetus mk3 extended With touchscreen: Hi flashed the ROM and now my touch screen no longer power on. is there anything I can do to fix it? It was working before.
    0
