Cetus MK3 Standard Version Cetus MK3 Extended Version
1.1 Introduction to Cetus 3D MK3 Printer Parts:
1.1.1 The core components of the 3D printer include the CPU, Motherboard and Extension PCB.
Mainboard |
Extension PCB |
CPU |
1.1.2 The main structure of the Cetus 3D Printer includes: X-axis assembly, Z-axis assembly, Y-axis assembly, control box housing, heated bed assembly, common print plate, 3D printer etruder, power cord, etc.
X-axis Assembly ![]() |
Mainboard Casing |
Z-axis Assembly ![]() |
Y-axis Assembly |
Heated Build Platform![]() |
Perforated Build Plate |
Extruder Unit ![]() |
220W Power Supply Unit |
1.2.3 3D Printer Parts
(1)Various Wiring harnesses for 3D printers
Extruder Cable WIFI Antenna Z-axis Motor Cable
Heated Build Plate cable X-axis Motor Cable USB Cable
(2)Flat Cable
Power Cable Motherboard Platform X-axis Limit Switch
Control FFC
Y/Z-axis limite Switch Adapter Cable Y-axis Motor Cable
(3)3D Printed Spare parts
Adapter Plate Cover FFC Baffle Z-axis End Cover with Limit switch cable
