Users may meet following error when using X5.
•Error: nozzle temperature too high
•Error: Calibration failed
•There is abnormal sound several times when the platform rises to the nozzle and no error reported
Cause |
Solution |
Remark |
Nozzle temperature is high during calibration or height aligning after the nozzle extruded |
Wait for the nozzle temperature to drop below 80°C |
Clean residual wire on the nozzle before aligning |
Height aligning cable damaged |
Unplug the height aligning cable connecting the height aligning assembly, disassemble LED set |
Short circuit or damage to height aligning PCB board |
Remove the height aligning assembly and replace the height aligning PCB board |
Steering gear is not powered |
Remove and replace the steering gear assembly, PCB board |
Mainboard damaged |
Turn off the power and replace the mainboard |
