Failure
- When X5 is connected wirelessly, there is no prompt on the connection, and the software control operation can’t be performed
- Unstable Wi-Fi connection state causes transmission model data to fail/crash after connection
- Error when connecting Wi-Fi: the printer is not responding
1. The wireless status of the connection between the PC and the Up Studio is different
- Restart the X5 and UP Studio software, and confirm that the display and PC are connected to the same Wi-Fi
- If the workspace has multiple Wi-Fis for different purposes, its Wi-Fi name needs to be distinguished from other Wi-Fis
2. Insufficient wireless signal strength / wireless signal instable
- Restart UP 300 and the software and reconnect
- Reconfigure wireless settings
- Replace a more stable and stronger wireless signal
3. Software version problem
- Download the latest control software from the designated official website
4. Wireless router is not compatible
- Check the router type. Currently, the UP Studio software only supports wireless router in the 2.4GHz band. It is not compatible with other routers and needs to be replaced with a router supporting the 2.4GHz band
5. CPU damaged
- Connect Wi-Fi with the PC in the standard procedure. If it can’t be connected normally, turn off the power and replace the CPU
6. Wi-Fi cable assembly damaged
- Turn off the power and replace the Wi-Fi cable assembly
