Tools
Cross Screwdriver/ 2.5mm Allen Key
1. Screw off the bolts by Allen key, and take down the short belt from X Axis motor.
2. Take down parts A and B, and screw off the bolts under A and B. Take down X Axis linear rail guide clip assembly after remove A and B.
3. Cover the shirt belt on pulley before installing linear rail, and cover X Axis belt of two sides on left and right pulleys (ensure the concurrently working of two belts to avoid the different distance between C and B in step 4), and install part A and B based on uninstallation, and fix the bolts.
4. Cover the short belt on X Axis motor, and tightening the screws. Pull X Axis to the front of machine to ensure the same distance between part C and D. Please adjust the position of the belt for E if the distance between two sides is different.
