The Wand Server Firmware package also includes the Klipper Firmware.
In order to update the Klipper firmware correctly, user need to update the Wand Server firmware all together. The update function is built into the Wand Server system, so user need to boot into Wand Server first in order to update.
Step by Step Guide:
- Disconnect the Wand Server from the printer by unplugging the USB cable.
- Power off the Wand Server by unplugging power cable.
- Plug in a USB drive that contain the firmware update file (.tt file) in the root diectory.
- Power on the Wander Server, it should boot into Tiertime Wand Server system instead of Klipper.
- Go to Info=>update, the system will search for usable update package. Select the update package and press "confirm" to initiate the update process.
- When update finished, power off the Wander Server, connect to printer with USB cable and Power on the Wand Server.
- Wand Server will boot into corresponding system (Klipper/Tiertime) depnend on the machine it is connected.
1 comment
Starting wand server with printer is not connected… Wand server starts with chinese ui.
Its a great idea from tiertime deliver this to europe 👍👏
