Auto Place: to let the software arrange the models’ placement automatically on the build bed.
Tools: Click “” to let the software place the model.
Actions: the model may be rotated horizontally. Multiple models can be in one build envelop.
Rotation: to rotate the 3D models into a desired angle along X, Y and Z axis.
Tool: Click “” to access Rotation Tool, and the Actions are X, Y, and Z options for X, Y, and Z axis, and X is the default option. The Value Text will be the degree which user enters for the model to circle along the axis chosen.
Actions: There are three rotating direction options. The X aixs, Y aixs, and the Z aixs.
Value Options: you can select from the predefined value options to turn the models along the selected axis.
Value Text: Allows user input the value to turn the model in selected direction. (+90C - -90C) Center Action: To select a facet on the surface of the model to become the base surface and drop the model down to the build bed.
Move
1. Choose the model and click the Move"" button.
2. Choose the direction of movement
3. You could input a specific value or choose a preset value for a distance of
4. Alternatively, you could use the translational guide on the model to move on the X-Y plane or a single direction by hold and drag with mouse.
5. Select Drop to print bed.
Scale
1. Choose to zoom in the axial direction, X, Y, Z of three axis can be freely switched;
2. Lock ratio is zoom of overall situation (default), users click to open by axial uniaxial zoom;
3. Enter the number that you want to scale in the numeric input area.
4. Click on the common numerical values to move directly, and the system provides six values of 0.5, 0.8, 1.2, 1.5, 2, 10.
Mirror: to flip the model at the selected direction.
Tool: Click “” to access the Mirror. Choose the axis to perform the action.
Actions: X, Y or Z axis can be chosen. To flip the model horizontally you can choose X axis or Y axis. To flip the model vertically you can choose Z axis.
Views
Users click on the view to select the perspective of the model you want to see, the system sets: top view, bottom view, left view, right view, front view, back view and free view of seven perspectives. Click on the different perspective of the three-dimensional model of the interface will be followed by switching to the corresponding perspective.
The effect of the user clicking the model display mode, as shown in the following figure:
The system is divided into four kinds of display modes, first: entity display mode (the default display mode of the software) three-dimensional model is displayed in the three-dimensional interface with the solid effect; second: wireframe mode, three-dimensional model is displayed in the three-dimensional interface in the form of only display line frame; third: entity + wireframe mode, three-dimensional model is displayed in the three-dimensional interface in the form of an outer frame; fourth: transparent mode, three-dimensional model is displayed in a semitransparent model in the three-dimensional interface.
Clip View: to look at the model’s interior structures from different angle.
Tools: click “” icon to access the Clip View; Choosing the axis along which the view is generated.
Actions: select one axis, X, Y or Z axis to adjust the viewport’s angle.
Value Text: to define the depth of the visible parts.
Centre Action: Reverse the visible part into invisible part.
Users can rotate the blue axis of rotation to rotate the transverse section, and it can also drag the transverse section, the model is displayed to the user by the effect of dissection.
Fix Errors: to fix model errors which can be detected by the software.
Tool: The model error will indicated in colour red. Click “” to let the software fix.
Display Mode: to present the model in various display modes.
Tool: Click “” to entering the Display Modes, and then select the suitable mode to view the model. There are four modes: Wireframe, Solid Wireframe, Solid, and Transparent.
Action: The four types.
- Solid Wireframe: the model with solid outline on the surface and core inside.
- Wireframe: the model with solid outline.
- Solid: the default display mode in the software.
- Transparent: the model with translucent core.
Top Right Bar Settings
The settings area includes: username, system settings, skin change, problem feedback.
【User name】Display the name of the current user,If the user does not log in then it does not display the username, user clicks the icon directly into the user's account page。
【System settings】Including select the language of the software, select printers, upgrade, clean up caches, network settings, and version declarations.
【Skin change】User click the “skin change” button which could choose the skin and color of default in skin change software.
【Feedback】User click feedback button which could send questions and suggestions to the software production team, as shown in the following figure:
A support ticket will be created after submitting the form (internet connection required).
