Printer |
Printing Technology |
MEM (Melted Extrusion Modelling) |
Extruder |
Single |
Nozzle Diameter |
0.4mm |
Extruder Maximum Temperature |
299℃ |
Extruder Maximum Travel Speed |
200 mm/sec |
XYZ Accuracy |
2, 2, 0.5 micron |
Connectivity |
USB cable, WiFi, LAN and USB Stick |
Display |
7″ Full colored LCD Touchscreen |
Build Volume |
180 × 230 × 200 mm (7.1″ x 9.1″ x7.9″)(XYZ) |
Printed Object Accuracy |
±0.1mm/100mm |
Layer Resolution |
0.05/0.1/0.15/0.2/0.25/0.3/0.35/0.4mm |
Calibration and Leveling |
Manual Calibration and Leveling |
Build Plate Maximum Temperature |
100℃ |
Build Plate Surface |
UP Perf, Heated |
Enclosure |
Full |
Dual Filtration System |
HEPA and Activated Carbon Filters Version 2 |
Supported Materials |
UP Fila ABS, ABS+, PLA, TPU and more |
Filament Diameter |
1.75mm |
Filament Spool Compatibility |
500 - 2000g |
Filament Spool Holder Compatibility |
500 - 1000g |
Pause to Change Filament Type |
Yes |
Out of Filament Detection |
Yes |
Tiertime Print Queue |
Yes |
Compatible with 3rd party Materials |
Yes |
Physical Dimensions |
Machine Dimensions |
850 x 625 x 520 mm(33.5″ x 24.6″ x 20.5″) |
Net Weight |
50kg |
Power Requirements |
Input |
110-240VAC,50-60Hz,220W |
Extra USB Input for Add-on |
5V, 1A |
Software |
Software |
UP Studio |
Supported OS |
Windows 7/8/10, Mac OS X, iOS 8.x/9.x |
Supported File Formats |
.tsk, up3, .ups, .stl, .obj, .3mf, .ply, .off, .3ds |
Preview Support Structures |
Yes |
Editable Support Structures |
Yes |
Cloud Print Settings |
Yes |
Ambient Environment |
Operating Ambient Temperatures |
15 - 30℃,20 - 70%RH non |
