Path Mode
Perimeters
Set number of perimeters
Infill Density
Support Density
The bigger the value the more dense the support structure.
Full Fill Area
Area threshold that override density to full/solid Infill. Area smaller than this value will be printed 100% infill.
Infill Path
Top Bottom FillInner FillSupport Fill |
Infill pattern for Inner Fill |
Infill Perimeters
Extra inner perimeter for infill
None: no infill perimeter
Always: Always print infill perimeter
Alternate: print infill perimeter alternately, this option may increase the contact surface area between perimeter and infill thus increase the bond strength
Support Perimeters
Add a single perimeter to support column to increase stability of support but may make support more difficult to remove.
with without
Fill Angle
The starting angle of infill pattern
Angle Increase
Fill Increase
Support Angle 1
Angle of support infill
Support Angle 2
Angle of sparse support infill
Perimeters/Infill Overlap
Overlap ratio between Perimeter and Infill
Bottom Overlap
Overlap ratio between Perimeter and infill for the bottom layer
