Fill Mode
Fill = Perimeter+infill+top/bottom
Shell = Perimeter+top/bottom (no infill)
Vase = Perimeter only (no infill, no top/bottom)
Perimeter Gap
When gaps are found in the perimeter, this value determine the gap size for auto close the gap.
Tolerance
+0.1 = X and Y plane both increase 0.1mm in size
Fuse Gap
Radius for small gap to be fused.
Thin Wall
Features that are not printable due to to small/thin will be retained and force printed. Dimensional accuracy may be compromised when checked but all features are preserved.
Hole Shrinkage
(only applied to vertical holes on a part, expand small holes to counter the hole shrink effect)
Maximum Radius: Threshold for applying shrink compensation, holes larger than this diameter value will be ignored.
Ratio: The bigger this value the more compensation for small holes
Maximum Shrinkage: Set max. Shrink ratio for compensation
Entity ID
different regions of a print, are marked with an entity ID, so that they can be assign to different extruders to print. The entity IDs are used in the Extruder Settings. Here user could define their own IDs.
