Extruder (1/2/...)Check box:
Check the box to activate extruder, the slice will include the material setting for the activated extruder.
Filament: Material profile, this can be defined at the Material tab.
Nozzle Diameter: Set the nozzle diameter. This value is not used for slicing but only for verification purposed.
Scale Factor: Extruder scale. This value will modify the overall extrusion rate of the printer. It could be useful if user modified the extruder or use third party extruders.
Entity ID:When entity ID is input here, their represented entity will be assign to this extruder for printing,
X Offset: nozzle offset for multiple extruder machines.
Y Offset: nozzle offset for multiple extruder machines.
Z Offset: nozzle offset for multiple extruder machines.
Switch Code: Gcode used for switching Extruders
