This error prompt is generated by filament monitor module. If filament feeding is interrupted and detected by the module, the printer will pause the print and display this error message on the screen.
User could examine the filament feeding path, check if there are any blockage/entanglement/clogging happened along the path. Some of usual cause of the problem could be:
1. Filament spool entanglement
2. Clogging of nozzle / hotend
3. Filament breakge/stuck in feeding tube
