Skip to main content
What is the Nozzle Offset and how it works?
3 comments
  • Susan
    This still does NOT tell me how the adjust the value!!!
    Do I use a positive or a negative number, and which way round does this affect the overall nozzle height?
    If the build plate is at zero then I add a value to raise the nozzle, but if the build plate is at +124.77mm then I need to subtract a value to raise the nozzle.
    This is not clear from the documentation.
    0
  • Jason Wu
    Final nozzle height = nozzle height value + offset
    the bigger the nozzle height value = closer to platform
    So if you want the nozzle to be closer to platform, either increase the nozzle height value or add a positive offset value; if need the nozzle to be away from the platform, reduce nozzle height value or add a negative offset.
    1
  • Susan
    Awesome :)
    Many thanks Jason for confirming the correct setup.
    BTW my UP mini 2ES is successfully printing in polycarbonate.
    0
